Ball joints interchangable with sh3 hatch?
A little question.
The right front uper ball joint , is it interchangable with the ball joint (the complete triangle shaped unit) from the hatch or sedan?
And I'm assuming you mean the whole upper control arm.... Honda doesn't sell the upper ball joints separately.
What I do when I'm trying to cross reference parts numbers is go to http://www.hondapartsnow.com and use their online database to look up both cars, and just compare the part numbers and you will see whether or not they are different parts.
