Drop Kits
Im sorry I am new to the whole honda ef ee thing......I need numbers so please if you can tell me the year to get for what type of honda whether it be a crx or what.......remember im new to all those initials im originally a truck kinda guy......but couldnt miis the oppurtunity to but the wagon for only 100.00 bucks thanks
In general you are just shortening the springs/struts to allow the suspension to sit lower.
When lowering a car properly I recommend replacing the struts with aftermarket ones. You can then chose to install lowering springs or coilovers. There are advantages and disadvantages to both. The last thing I recommend gettings is a camber kit. With the hondas when you lower them you get negative camber, so if you want to keep your tire tread longer install a camber kit.
Almost any suspension that's built for a 88-91 civic will work. Doesn't matter if it's a crx, hatch, sedan or wagon.
That's the basics.
thanks a million man i appreciate it.....so i can go on ebay now and order some shit....thanks again
