Tranny fill bolt removal
I just got done loosening my transmission fill bolt, and SWEET JESUS! The bolt was put on by Satan himself. I remembered in a forum somewhere, that someone said to be sure to pop off the fill bolt before the drain just incase the fill would not come off. This is so you wouldnt be left without a ride hehe. After 1 hour of ghetto impact wrenching with a hammer, pulling on it with all my weight, heating up the bolt, WD40 treatment, stuff thats supposed to loosen bolts quickly, I finally put a little full body Foot Power on the bastard while my bro held the wrench in place it popped loose. I thought I had surely stripped it! , but then I went to look and the SOB was loose and still intact!! OMG never again, i put it back on with recommmended torque.
Anyone else had this problem?
Seriously. This thing is misplaced anyway. And then it doesn't come off. Sheesh.
I will try the VSS trick next time though.
Man i wish i knew about the VSS going into it. I guess now mine is free of the rusty shackles, I have to loosen it every few months to make sure it doesnt bond itself together again lol.
I'll try the reverse switch... if my s80 has one in the same position.
