RT4WD Wheel cylinder - any other models compatible?
Hey guys,
I'm kind of in a jam here and need to know if a rear drum wheel cylinders from any other model will fit my 91 RT4WD. I've got a race this Sunday, and when I went to bleed my drums, the bleeder bolt broke because it's so rusted. No one has the RT4WD wheel cylinder in stock, but they do have 88-91 Sedan/hatchback, which I assume is different. Anyone know if one from anything else would work if they had that in stock??? Hoping to find something in stock tomorrow morning to get this rockin.
Thanks!!
Thanks!!
Good Luck.
Go Fast...
but smoooothh...
ahaha
LOL
Every parts site I could find lists the parts different. They're either listed as 'Sedan, hatchback' or 'Station Wagon', but not in the same. Drums are different for these models too unfortunately,so I assume the wheel cylinder either has a slightly different shape or is larger due to the weight.
Anyway, I ended up picking up a couple at NAPA today. The guy said they were for the wagon, but these definitely wouldn't fit as is. I had to grind them down a little, as well as around the rear of the drum to the holes would line up. Ended up getting it though, so all's a go for tomorrow's race!
just my 0.02 cents
wagon.....................................4ever..........................
