new fuel pump blues
We put a new fuel pump in this 90 ex we bought from a friend of mine. The car hadn't run for a year and we deduced the fuel pump wouldnt' run. It was getting power but no action so we dropped the tank and r&r the pump. Now the car runs but when you take it up the road thru 1st, 2nd, 3rd by that time when you step on the gas the car shuts off unless you let it back to idle. If you stop and restart it the car will have power for about three gears again. It acts like it is running out of gas. if you leave it running after one of these spells it hunts for idle. Also where is the fuel pressur test tap?
Thanks for listening!
Tim
Tim
It would drive fine and then for some reason it'd shut off... fuel starved... and then after a few minutes it'd fire right back up...
you'll have to either replace the tank, or just clean it out really well...
how are things working out for you so far?
