Ground Control Spring dimensions?
I am curious to what the dimensions of the ground control springs made by eibach are for ef's?
I have looked all over for civic spring dimensions height x inner diameter x spring rate with no luck.
I will call them when they open. The springs are really cheap and I am woundering why, I must be missing something.
They describe them with Eibach Springs, 0600.225.0425 code. Which to my understanding is: 0600=6 in. height, 225=2.25 in. inner diameter, 0425=425 lbs./in spring rate.
http://www.ground-control-store.com/pro ... php/CA=211
Anyone that can fill me in as to why the price is so low or more info would be awesome.
I really need the length and inner diameter more than the spring rate.
I'm pretty sure the ef inner diameter is 2.5 in.
So if I could get someone to find or measure the length of their lowering springs, I would love you long time
I was wondering what the dimensions are for the ef. I wasn't sure If there is a certain length that you have to get or if the measurements differ from lowering springs.
I must not have explained what I was looking for clearly enough :oops:
:arrow: Another thing u may want to consider.Coilovers have flat ends .OEM facts:one spring has 1 side w/a flat end & another 1 has a bottom w/a different dia. from the rest of the spring.
I have several sets from various previous setups.
You are right in your understanding of the coding....So I'm not sure what you are asking for?
I have them in my garage...let me know exactly what dimension you are looking for and I can get it....because it looks like you already know the dimensions....
Cheers!
Jeremy
