Opinions please
Ok, so I went to look at a wagon for sale near me. Guy wants 1k firm. car has 170k miles.
Seams to run ok, guy says it has a problem starting now and then.
the good:
low-ish miles
yr88 paint(needs a clay bar and a wax stat)
clean-ish interior
excellent mechanical records
new tires
clutch done 40k miles ago
passes smog (important in california)
Bad:
pulls to the right. Guy says he took it for an alignment and the shop "couldn't bring it into spec"?
maybe more dents than I want to deal with
was bumped on the drivers door bad enough to push the door jamb tensioner into the body. door is sagging a little and there fore leaks at the top. guy tryed using silicone caulk to seal the top up. made a mess and did not work.
AC works but doesn't blow cold air. took it to a honda specialist and they quoted him 900 to get it working again.
What to do...
the good:
low-ish miles
clean-ish interior
new tires
Bad:
What to do...
thats what it is...
I like horror...
I think...
As for the yr88 wagon. Also has no roof rack or passenger mirror. are these common to find elsewhere?
yr88 wagon, common, i dont think so...
quite common these days, yes...
i see that almost every day...
http://sandiego.craigslist.org/csd/cto/1501472830.html
And as for common to find, I was refering to the stock roof rack and passenger mirror.
