noobie from so-cal
hey guys im in the market for a civic wagon i just sold my daily driver and i wanna start with a solid wagon!!!
here is a picture of my civic(daily until if find my wagon)
and here is my other civic that i recently sold
let me know if you guys have any good wagons for sale!!! in the southern california perferably! thanks.
Where in so-cal do you live?
Good luck on finding a wagon..Im on the hunt for one too
looks solid though
If you have the extra money, I say fix it! At least the body looks to be in pretty good shape.
Agreed I think any wagon you buy is going to need some tlc!
ahh i just found out today that it needs a clutch pedal bracket! wtf im ordering that part right now and i just order a pair of gas shocks for the tailgate/hatch anyone near socal think they can help me with the bracket? or can i pay one of you wagon experts to do it for me?
ahh i just found out today that it needs a clutch pedal bracket! wtf im ordering that part right now and i just order a pair of gas shocks for the tailgate/hatch anyone near socal think they can help me with the bracket? or can i pay one of you wagon experts to do it for me?[/quote]
clutch pedal bracket is wagon specific. you can install the pedal bracket fom other EF's but the clutch portion will interfere with the plastic a/c vent tube to far left dash vent. I recommend you reinforce the new pedal bracket around the clutch pedal pivot area as this is a known weak point and is likely to break again. it is not terribly difficult to replace the pedal bracket but it is time consuming. wish I could help but I'm in the process of doing my own also. let me know if you have any questions.
for...
better do some midnight pictures!
:shock:
well here you go, this camera did not pic up all the mess you had to be there to see how bad it was
and here is the pic of the bracket
and 1 install picture
what a mess
was about to get my torch...
...not...
was a pain in the ass, i also replaced all the grounds which made the car run better but the idle/vacuum problem still exsist. this car sometimes idles on its own and then other times it revs hang when i shift! what the hell causes these symptoms??
you have to let the engine get to operating temp first (make sure the fan comes on). Unplug the two 2 pin connector at the EACV and make sure no electrical loads are on. Adjust the idle screw and set the idle to approx. 650 RPM.
Turn off the ignition and plug in the EACV. Reset the the engine control unit by pulling the hazard fuse at the main fuse box located under the hood at the right shock tower for about 20 secs. Start the engine again and let it idle again
with no electrical loads on. The idle should be approx. 750 RPM. Let the car idle for a few minutes then turn on the headlight high beams and rear defogger. The idle should bump up to approx.850 RPM. Try these and see if any of it helps.
civic wagon no respect
LOL how many times have we heard this?
At least you have some fun Hawaiian print seat covers.. That's the way I roll..
oh and the idle thing happens when im at standstill and when i shift it seems that the car rev hangs. it got better when i clean the iacv but its still pretty bad
no
