Are Crx front strut bar compatible?
There is a guy with a neuspeed front strut bar (over the engine) from a Crx. Are they compatible with the wagons?
Did a quick search but I'm still a newb at searching on this site.
Thanks
Shane
Thanks
Shane
Ill let others chime in with what they have used and works.
As already mentioned, if the ends of the rear bar are solid (the bar is a 1 piece design, welded together) it'll be too long. If the ends are adjustable, it's possible that they could be adjusted sufficiently short for it to fit. I just cut my 1 piece bar in 2, shortened the center piece, and welded it back together.
