which LCA is shorter?
i was planning on doing a rear sway bar setup. i have searched that the DA or the civic SI 91's have the open bolt locations on them to mount the endlinks.
i dont want to have the wheels come out of the fenders, i would prefer if they were comming in so that i can put wider wheels on.
which one would be shorter?
or is there any other aftermarket ones that would also work and be shorter?
Correct me if I'm wrong :P
That is the case for Skunk2 for example:
http://www.skunk2.com/mm5/merchant.mvc? ... 42-05-0105
why is the 88 civic and integra type R different?
On another note, those LCAs (1988 style) were used on all the JDM cars, right through the run from 1988 to 2001 (except 1996-2000 Civic EK).
http://ef-honda.com/ben/EFhybridsus.php
The cars "rotated" a little too easily, which lead to some unwanted oversteer situations that lesser mortals were not prepared to control.
