i got the first 4wd engine mounts from innovative mounts
just finally installed them. they are alot more stiffer. if you need a set let me know and i can get them for you. not sure of the price yet. pics to come soon. you choose three different stiffness on the bushings.
I just ordered a set of the inserts for the torque mounts as they seem to be very similar for my d-wagon.
i worked with them for the past year now, trying to get this done.
they are steel and poweder coated black.
the way the tranny side sits on for the 4wd wagons, it wont allow much room to have billet work.
i was trying to get away with only 3 mounts, rear, passenger, and driver side.
the front mount will be needed, cause there is some movement.
What if I just wanted the right side tranny to chassis mount?
i have been working on this for a while and it didnt work the first few times around.
so i didnt do it this time thinking it may not work but this time it worked.
i am still waiting on the fourth mount.
the only mounts are on my car. they only seem to make them per order. they dont stock them. unless i give them pics they wont have any pics.
you should, and keep us posted on how it goes. since i didnt take pics you should take them before you put them in and after you put them in.
for anyone else let me know and ill get you a deal on them but if you get a few people together it would be much better for the pricing.
x2
and price too>>> :P
I take it from reading, no replacement for the tranny to rail mount ?
now i asked them to make the front ones too. so you get all four. since there wasnt any real mounts on the fronts they fabbed one up. it works with their competition bar.
if you dont have a 4wd wagon, then regular 91 ef civic mounts will work fine.
Do you have pics ??
I've lowered my engine in the bay with washers under the bolts. Temp measure, I want to extend the bolts a bit for more thread.
Pass tranny mount is very short on spare thread.
I simply unscrewed the studs from the mounts, and used longer bolts instead.
I sent them one of my rear diff mounts so they could look a copying it, and they said they could not do it because the diameter was too small to fit their off the shelf mount bushings. I even offered that they could make it larger diameter because there was room for it under the car with some minor mods to the mounting holes, etc... and they said "not interested" because all they want to make is bolt on stuff.
Exactly man. But god damn. How you got those ones out...
I've been seriously trying but mine just wont shift for nothing.
I got two washers in for max. I need more tho.
I was lowering the engine for 2 reasons:
1 - to gain clearance between the blower drive snout on my supercharger and the bottom of the master cylinder, and...
2 - to align the u-joint angles on my 1 piece driveshaft.
I may be in a position to remove some of these washers soon. I will no longer need as much blower/MC clearance, as I'm going with a balance bar dual MC setup, so I won't need the rear of the motor to be quite so low anymore, and subsequently the front of the motor will be able to come up as well, and still maintain the correct u-joint angles.
But that son of a bitch is dug in like an Alabama tick.
