Noisy front end when going over bumps and turning
I hear a decent amount of clunks and sqeeks when driving over bumps and turning. Could this be bad bushings in the front suspension or a steering box problem? Any help aor comments of similar experiences would be great.
Car is a 89 standard wagon w/ 157k miles and stock suspension.
Thanks
Dan
Thanks
Dan
Exactly, it could be a number of things in the steering/suspension system. Have a good look over at all the components and go from there.
I just recently had the same problem with my wagon. There were clunking going over bumps and the wheel would shimmy. I had to replace left and right upper control arms and both tie-rod ends.
Where did you buy your parts?
I found a ball joint/tie rod kit on ebay for $129 shipped.
thanks
Dan
