My bushings are shot : (
Both front and rear suspension bushings are done. Has anyone done a full blown bushing replacement on their wagon?
Do you recommend poly or rubber?
Ant suggestions on where to purchase?
Thanks
Dan
Thanks
Dan
If yours is an RT4WD you'd want to look at the diff isolator bushes as well.
you can use any EF bushing kit.
rear trailing arm bushings are the same from 88-00' i believe. stick with rubber bushings instead of poly, unless the place you live has roads like glass. don't forget to do your radius rod bushings.
the difference of road feel is huge.
if you go poly, energysuspensionparts.com has everything you need.
I'm using all oem bushings...I went down the poly bushings road before and I never want to go back that way again...what a mistake it was, oem all the way for me....
bought a shop 12 ton press from harbor freight to change my wheel bearings and while I'm at it I'm changing all my bushings....the press makes life easy.
great link below to change wheel bearings:
http://www.honda-tech.com/showthread.php?t=1567042
just changed all the motor mounts with the hardrace motor mounts....starting to regret that too...should've went oem...doh!
the 12 ton press was $130 and comes with free arbor plates
you will also need the bearing separator at $15
the online prices are a few bucks more than instore...don't know why
press:
http://www.harborfreight.com/cpi/ctaf/d ... mber=33497
bearing separator:
http://www.harborfreight.com/cpi/ctaf/d ... ion=Search
the initial cost will pay for itself the first time I use it...
