OEM suspension parts compatibility
Hi guys,
Just wondered if you could clear some things up for me..
1) Wagon shocks are a bit longer than HB/Sedan/CRX shocks..?
2) Are the front forks the same as HB/Sedan/CRX forks..?
3) Are the rear LCA's the same as a HB/Sedan/CRX..?
4) Are the front brakes the same as the Si HB/CRX?
Thanks!
Thanks!
Front forks are the same AFAIK.
Rear LCAs are the same, year dependant.
Front brakes are the same, year dependant. The RT4WD got the bigger pads from 88-91 whereas the Si only got the bigger pads from 90-91.
yeh sorry thats what i meant with the shocks
thanks for the help Haydz!!
my wagon has some rusty bolts i want to replace, so may as well get some parts just incase
i may try and upgrade the front calipers/discs to 262's too
