Rear Wheel Hub Assembly
Does anyone know where to purchase new rear wheel hub assembly for the RT?
I ruined two of my rear left studs and the bearing is almost out and i want to replace the whole thing. I called the honda parts store and they said that it was discontinued. i really don't want to go to a junk yard and pull of a whole trailing arm just to get the bearing assembly due to having to press it out. I've tried nappa, autozone and shucks o'rileys in the greater seattle area and kept getting the same wrong bearing that doesn't have the splines for the rear axles to bolt up. If anyone has any info on where i could find one i'd appreciate it much.
Thanks,
TooRandom
EDIT:
Here is a picture of the part just for reference (not actual one for the wagovan)
https://www.carpartsdiscount.com/auto/a ... sembly.jpg
Thanks,
TooRandom
EDIT:
Don't forget those 4 Torx-headed MFers.
:oops: You're right,but that still doesn't get hub out of the brg.There's 2 ways:1)Press it out. 2)Ghetto way.I took a socket the size of the hub end & a 2.5 lb.(1 kilo(aprox.) hammer & went to town.The only possible prob with this is inner taper got dinged ever so slightly.I think this was OK 'cuz it could be grounded w/a hand grinder. I think the taper sits on the axle & doesn't spin(grind) on the axle.This is what I did,SO don't blame me if it doesn't work.In the end you'll probably still need to press it out ,cuz what I just described is just to get the hub out.
eek. thanks for the info guys. would anyone randomly have the part number for the bearing? Im afraid to go to a local schucks or nappa cause they're computers say different things with parts.
