Thanks for sucessful rear springs and tow hitch
I just wanted to post that I have succesfully utilized Acura front springs to replace the tired springs on the back of my 89 Wagon. It raised the rear about 1/2 inch above centerline, and it really made a positive improvement for handling.
I have also successfully adapted a hitch to the back. I used it yesterday to tow our tent trailer and it did a pretty satisfactory job. Adapting it was a real bear and it would not have been possible without an arc welder to fabricate adapter parts. i utilized tow hook mounts as well as a through the frame bolt at the rear of the bracket. The tow hitch isn't going anywhere, but adapting it to the curve of the frame was a real bugger.
Thanks
Thanks
could you post some pics of the tow hitch you adapted.
thanks
wagon........................4ever..................
i want a postcard...
where's the picture?
As far as the change goes, overall I would highly recommend the spring change. The car drives and handles far better, in my opinion. As far as towing, I need to fabricate some mirror extenders, before I feel comfortable I can drive it without getting pulled over by the Polizi.
hi gp. i thought that 1st gen tegs have torsion bars for the fronts. pls correct me if im wrong.
hey gp can you confirm this??
