Gerbils in my wheels?
As I was creeping along in the school dropoff line, I heard gerbils in my driver front wheel. At least, that's what it sounded like: squeak, squeak, squeak. I put it in neutral and revved the motor; no change. That makes me think it's a wheel or transmission thing.
When I'm going *really* slow, it sounds like the wheel is haunted: creeeeeeeeak... creeeeeeeeak. The faster I go, the more frequent the squeaks are, and the higher-pitched they get, until it sounds like Alvin and the Chipmunks experimenting with speed metal.
It's really quiet, too. I never would've been able to detect this with a gas engine running. The radio drowns it out completely, and even the transmission noise covers it up around 30 MPH.
I'm thinking wheel bearing. If so, I can wait a while before fixing it, although there's a possibility of replacement on Sunday. Are the Wagons known for some other failure that I should be taking into account?
The brake pad squealers (wear detection metal tabs) will only make noise when you are not braking. If your pads are getting close to being worn out, this is the expected behaviour.
It could be as simple as a small stone that is trapped between the brake rotor and the backing plate.
I was going to fix it on Sunday, but everything in the world got rearranged and messed up all my plans. I swept it all off the table and declared a Day of Rest. (That didn't work out as well as I hoped. Turns out we've still got to have groceries, or we're not going to eat. And they don't just deliver themselves to my door. Rats.)
Now it'll have to wait for next Sunday. Meanwhile, it should be easy to check out the brake pad squealers, and maybe even get it up on stands and inspect the rotating pieces.
wagpn.............4ever......................
wagon..........4ever............
There was even a minor panic when the car wouldn't move off the lift (inertia switch had triggered).
But now it's fixed, and it coasts much more nicely. It's a real pleasure to glide along. Between the new bearing and the custom alignment, I think I've improved my efficiency 10%!
I wrote about it on my website, too: http://judebert.com/progress/EV/Wheel-Bearings.html. I didn't get pictures, or I'd post it here.
