take out power steering / install manual steering?
Aloha from Hawaii!
Got myself a 91 wagon 2wd with power steering. Dont like power steering and I want MANUAL steering instead.
Guess my question is which year and model Honda/Acuras MANUAL steering (BESIDES ANOTHER WAGON) is a DIRECT bolt in for my 91 wagon 2wd?
Anyone ever do that swap before?
Thanks in advance.
Thanks in advance.
I kept the reservoir with mine. The three lines coming from the PS all run straight to my reservoir so the PS rack pulls and pushes whatever amount of fluid it wants.
edit: Oh and all 88-91 Civic/CRx racks will work. HF's and Si's have the quicker steering box's.
Depowering the power steering will work, but results in a lot *more* resistance in the steering than a manual rack. Personally, I don't like it. Some prefer it, though.
Another more involved method would be to remove the rack and pack it full of grease and then seal it all back up.
I was under the assumption that the rack had to be free flowing but I guess this make sense due to the fact that it is a power steering pump. Maybe I will just ditch the reservoir too. What did you do with the third smaller line?
Uh... Yah! I just made this s-h-i-t up. I pulled it out my a-s-s. I've never done it before. I don't know anyone that's done it before. I've never driven a car that was set up this way. WTF?
The key is to drain most of the fluid out of the rack. Otherwise you're pushing the fluid through all the small orifices in the rack. DUH! With next to no fluid in the rack, there's no more resistance than a regular manual rack, other than the possible increased effort from a faster rack ratio.
Now try a manual rack with the Quaife rack and pinion guts in it. That's a measured 2.4 turns lock to lock (advertised 2.82). Now throw some 285/30-18s on the front of the car with about 200 ft/lbs of torque and an LSD. You wanna talk about steering effort? Try aching biceps after a 45 second autocross run.
How is anybody supposed to know what you run or how you run it?
Please just post up your information and explain how and why you know it works. This will keep others from getting upset and we can continue this discussion and keep yet another thread from getting locked and forgotten.
Kind of like a two liter bottle that is full and one that is only say half full. The fluid can't move in the full one, but the fluid can move in the half full one.
Sound about right?
I'll let you know after I put some miles on mine.
Everything is fine! No problems, no leaks! Just looks like I have a PS reservoir thats half full with lines running back behind the motor. Steering rack doesn't seem to be taking any negative effects from doing this. Only downside is the little extra force needed to steer when I'm pulling out of a parking space or something.
viewtopic.php?f=8&t=8991
Now i start thinking.... People want to change out to the manual rack because it's easier to turn because of a different ratio. I'm thinking that I like the quicker steering of my P/s (i've been driving it around with the belt off the last couple of days).
So I start pulling everything apart. I jump under the car only to find three fittngs on the power steering rack??? So i wanna drain most of the fluid out and loop the lines and then loop the fittings together.
How does one go about this? is there one line I leave opened or cap off? Do I need a T fitting?
I have the pump taken off and hanging. Tomorrow is the day I have to get back to my wagon and get it fixed.
My friend just flew in from Afghanistan Yesterday morning so I no longer have his GTI as my backup vehicle while I'm working on my wagon.
I have three steel lines running into my rack. Did you guys find the correct fittings to replace these lines so you have three hose barbs coming out of the rack to connect together? Or did you just cut the steel lines and slip a hose over them and clamp them down? Does anyone know what the thread diameter and pitch is on the fittings if I were to look for the correct ones? Ideally I'd like to get the correct fittings and "do it right" but cutting the hose is an option too if need be.
I tried it out first by just taking the belt off. easy enough huh!
i didnt lope any lines, or anything.
I took it all out, drained it, and left it.
been that way for 5 months with no problems
Yeah I drove my eg for over 2 yrs with nothing hooked to the rack, I never noticed any change other than the lack of power steering.
i have to go back to jy for last day of 50% sale.
wagon.............................4ever.......................
The reason is the Wgn with PS has the shortest lock to lock of the Civics(&CRX).Zoomintegra(@ team-integra.net) converted a Teg PS to manual by using the "Loop" method,but went another step by removing the 2 valve/springs from the rack.This frees up the exiting oil from the rack .So makes turning easier.The same should work with the Wgn.
wagon.....................4ever...........................
got it and installed everything except for the pulley. its freakin hard to take off. ill try use a airtool today and take it off and install the pulley and belt.................
wagon...................................4ever..............................
