clearance on inner wheel and caliper bracket
I just got some new wheels for my wagon and when I put them on I noticed that on the inside of the wheel, on the area where the wheel meets the rotor, is rubbing against the brake caliper bracket. Any ideas on how I can take care of this without spending a lot of money? could I do it myself? it only needs about an 1/8" for clearance... here's a pic of what i mean, look in the red circle. Any suggestions would be great.
a wheel spacer 1/8" ? oompff..
double that, yeah on every
corner
ps. size studs ...
and i dont know..
a lot of money ?
1/8" is only like 3.xx mm and that is totally fine to sandwich in with stock studs if you were wondering. Finish up the thread so it doesn't leave a dead end like so many others!
AGAIN not recommended I am just lazy. .
I'm in the process of finding some other wheels.
well I had the same issue with that steel wheel so all i did was take my dremel and ground a bit off the caliper bracket.
wagon.............4ever................
You can use a small spacer with stock studs but be sure you've got adequate threads - in the case of my wagon, someone before the previous owner trimmed the studs down so they're stupid short, I may end up having to replace them with longer studs just to run my MR2 wheels without issue.
