Where to get rear drums for the 90-91 RT4WD???
Does anyone know where to get rear drums for the 90-91 RT4WD? I am running into dead ends with all the parts stores as they are trying to sell me the smaller sized drums. Ordering these from Honda directly will cost a fair bit and may take longer than expected. Apparently mine are not able to be re-surfaced and I'm in need of new ones soon so I can get back on the road
I was able to find an acdelco part that would have fit if they didnt go ahead and discontinue it
anyone with part numbers or sources for any?? your help is much appreciated
Thanks!
Thanks!
Anyways here is a snip from their website www.rockauto.com
Thank You
any updates?
so that might be easier to get parts for
:!: NOT :!: The drum is Wagon Specific.
The problem currently is that some Data entry idiot some where has entered the Wagon drum as a Ordinary Civic drum.That's why we're getting the small civic drums.
All I ask is the total cost of shipping, plus $10 for my time to pack them up and get them shipped.
At least you don't need rear brakes very often. Good luck, and let us know if you find a reliable source!
they both are for me. mind you mine are both JDM... but i have had the drums off my shuttle and coupe and compared the shoes and drums and they are exactly the same. same markings on them. 201mm if i remember
I hope not because I wanna put new shoes in the rear when I finally get around to putting my DA spindles/ brakes on the front.
You guys may wanna check them out.
http://www.bap-geon.com/ContactUs.aspx
some are really cheap
Bap Geon does carry them.
Check the pics for part numbers. The maker is OP Parts.
viewtopic.php?p=68005#p68005
