my 88 wago
hey everyone figured ive been chatting to all the wagon fans on this forum for long enough and i finally got my camera to work so heres a quick pic of my wagon. i bought it from a random guy who stopped into NAPA autoparts where i work for 800 he couldnt figure out the notorious main relay problem. haha so far the only modifications ive done are miata wheels and a cold air intake that is mounted where the resonator used to be. in a week or so im probly going to slamm this bad boy and do the top hat mod. I am very interested in fabrication and want to see how this works. sorry i only have one pic but its a start.
and welcome.
also upon lookin at the head a little closer i did the install with a z6 head not the y8 sorrry ha
wish me luck hah
sorry to brake the new to you that distributor wont work any more, and you cant just splice extra wires off the dpfi one's
as that would be and easy approach it just wont work. funny though i met a good friend this way some guy did his swap to LS and did it this way. to my surprise he did get it to run but it only drove when he floored it it popped and whined took almost a whole tank of gas to get 10 miles to my shop, and burned the mpfi injectors out to boot wich further complicated what i had to do :roll: look in engine and drivetrain go to engine faq then to dpfi to mpfi. got something in there for you
I concur
It goes in this hole...
The vtec head has this restrictor built in, so if you don't remove the one from your deck you'd be running dual restrictors which will eventually lead to cam seize, snapped cam, bent valves etc.
