front engine mounts one 4wd question?(solved)
i was looking around and i couldnt find a direct answer.
what other civic specific would have the exact same front engine mount as the 1991 wagon 4wd civic?
or are they just different and the wagon 4wd 1991 civic just specific for that model and year?
Thats the part number i thought it was. Try and cross-reference that against other models. Being SH3 i'm assuming it is used by others.
the reason i ask is because i had innovative mount make me one and it doesnt line up.
the cross member they made which replaced the old one in the front (which is right under the radiator) doesnt line up with the front engine mount location. it seemed to have shifted to the left while the engine bolt is to the right.
right now they are trying to figure out if its the crossmember or its different because mine is a 4wd.
i believe the front crossmember that they made is off. its not at the correct location.
i always thought that mount was for obd0 b-series cable trans/motor swaps? just a thought 8)
yes you are correct. they just told me the crossmember is to a B series engine swap.
so they just made a mount that will correct the offset position. i got the prototype for the front mount yesterday and just put it on this morning. its not pretty looking yet but its in. it should make the whole engine much more stable then with just 3 mounts in there.
im just testing it till a new final better looking one comes out next week.
the fitment is off a little right now. they will make the correct adjustment on the final one which ill test out next week, hopefully.
pics will be up once i get a working digital camera.
