Replacements/Swaps for 88 4WD LCA
Can I swap out my LCA's on my 88 4WD with other EF's?
And would it be hard to do this conversion?
I'm not sure if there are any other post about this, can someone point me in the right direction if there is, because I just spent 1 1/2 hours looking for this answer.
I've read post that explain the difference but no one says what can be swapped in. Let me know.
will bolt into a 88. just use an 89+ strut
The LCAs from the 1996-2000 Civic are longer than the 1988-1995 LCAs. Put those on your 88 Civic, and you'll have about 15 degrees of negative camber :shock: .
i got that assumption from skunk2 selling the LCAs for all 89-00 :?
lolz anyways
http://www.hondacivicwagon.com/board/vi ... 2379#42379
I know there is a difference and will all this bolt right up? I'm just wondering if it will bolt up to the brake assembly, because it looks different.
http://www.skunk2.com/suspension-2.php?code=LCA
LCA OK.CRX trailing arm NO.
http://www.racinglab.com/suspension-sku ... l-arm.html
obviously they are incorrect, should have just gone to the source
In your link the Civic 88-95 and the CRX 88-91 have the same part numbers.
