lifting a crx
sorry to bother you wagon folks with a crx question. but i have been reading up here about springs on your wagons. I have a 90 crx and i need to lift it up.
If i am reading right would da springs give a crx 1-2" of lift?
I have found alot of info on here and it seemed to be that da springs would lift a wagon that much. unfortunately i have also read on here that the front da springs are the same height as the wagon. so im a little confused. i have measured stock crx spring and the height while off the car ar 13".
can anyone confirm the height on da springs?
I think you'd need to use crx/hatch or DA shocks. Wagon shocks would sack the arse out of your CRX.
Its ASS Haydz!!! LOL!!!
But back on topic, aren't the RT4wd struts and springs good for lifting CRX/Civics??
And its arse. :P
so i dont think the length of the shock has an effect but rather the location of the shock perch on the body of the shock. if it is welded 2" higher then the car is 2" higher. i dont think i can cut and reweld the shock perch without totally screwing up the shock however.
i do know that off the car the crx stock spring is 13" tall. does anyone have any other stock springs laying around?
http://www.hondacivicwagon.com/board/vi ... 2379#42379
ok so to quote
if im reading this correctly then either dc or 2000 civic si springs will lift an ef/ed.
could i also interpret that to mean that any springs from 2000 would work? what years where those anyway 96-00???
ty sir
