Brake Warning Light Is On
My brake warning light on the dash came on today. I know it's not the emergency brake. The owner's manual I may need brake fluid or have a leak. I'm going to check the level and add some fluid if needed. What kind do I want? Where is a deal on it? What will it cost? How much should I buy?
you need DOT 3.
you dont need a lot. just a couple tablespoons to fill up the reservoir lolz.
cheap cheap cheap.
