Rear lower sway bar
I really need to get my digicam fixed :roll:
Well, its really pretty easy. Now keep in mind that I havent done this to a wagon, but it looks very similar underneath.
This is what I did. Aquire a swaybar from a DA, (sedan for bigger bar) and take the two bolts that hold it to the LCA's. Then remove the four bolts that hold the bracket to the chassis (two on each side).
Now on your car bolted to the framerails are two tow hooks held on by three bolts a piece. Remove those and save the bolts. The DA brackets will be able to bolt into those holes if you swap sides (left to right etc) with the brackets and elongate the holes a little.
Now for the part that is kinda not just a bolt on. Some of the fourth gens have the LCA's with a little stub on them where the Si swaybars bolt on. Some have this stub with no hole or threads. You can drill this out and tap and your good to go. Some of the LCA's dont even have this stub, for instance the AWD wagons like mine. What I did here is drill a hole in the center of the LCA and tap some thread into it. Its a very thin piece in there so I got a longer bolt and put a nut on the other side jsut for a little stronger setup.
This has kinda gone off topic eh? But Ill try and get my camera fixed and snap some pix. Mine is a lot different, but Im sure I can get the point accross. On my gf's car I had to space the bar down about 2" for some clearence issues, but havent had any issues since. Im sure you could go to the slavage yards and find some Si LCAs too. That way you dont need any special tools. Anyway, hope that helps a little.
Now anyone who has input on this topic is free to discuss it here. I know this is definately going to be one of my mods!
http://p196.ezboard.com/fhondacivicwago ... D=36.topic
In a nutshell:Get '89+wgn.rear shocks;89-91 Civic(not wgn) rear shocks(OEM or aftmrkt) & cut DA springs (or aftmrkt CRX springs).If confused after all that.Ask me mo :?: :?: :?:
I still gotta find a DA anti-swaybar
Thanks in advance!
Oh and the DA LCA's help with camber.
Da Brackets
Da Sway
Da rear lower control arms
Feels like a different car.. haha, much much more stable in turns and much more predictable.
