Bad CV joint?
Allright Well Latly my car has devoloped a squeek type of noise in the the front left damper/strut, at first i thought it was just dirt or water up in there. but its been over a week and still squeeking at every bump in the road. Do you guys think its a ruined bushing or somthing else???
go under the car and see if the rubber seal sections are open or torn..if they are, then you need a new CV boot/joint..axle.
axles run about $60 each for the wagon.
