confused about spring options
Are there any lowering springs available for wagons? All the ones for civic/crx say specifically "except wagon". :x :x :x I would rather not go with a coilover setup, and have regular lowering springs instead. Am I screwed? Are coilovers the only option?
thanks in advance.
EDIT : I found the old civic wagon board, and was able to learn a few things. So, I need CRX or hatchback rear struts, and then I can use any crx/hatch springs... but what about DA springs? I want to be able to load this car up with luggage and people and not bottom out. If I wanted to use DA springs, what struts would I use? The car is an 89 front wheel drive.
thanks in advance.
http://p196.ezboard.com/fhondacivicwago ... D=36.topic
Does anyone else have this setup? I'd love to see pics.
i actually considered doing the DA springs with EF struts, but plans fell thru and i ended up getting coilovers (i got them cheap tho). are you going to cut dead-coils off? someone around here has DA springs on their wagon for a slight lift.
yeah, but they don't use EF struts. I would like to see DA springs on EF struts.
i think the only way would to cut coils off.
see my posting in Members Rides..under my posting..i answered your question there with a few photos.
send me a msg if you have more questions.
would something like this work on our stock struts/shocks???
