RT4WD waggy sway bar!
If one looks close at the link in this tread http://www.hondacivicwagon.com/board/vi ... php?t=3723, one will understand the differences between fitting say bar in 2WD waggy and RT4WD waggy..
I've done it, but it doesn't work the same way as for 2WD waggy!
2WD waggy doesn't have differantial bussiness hanging above rear sub frame.
It can be clearly seen in this picture...
This moves links further away from LCA. (about 2 inches)
What I've done was I used spacer to compensate for lenght difference.(for now).
I am planning to use heim joints that I have to complete sway bar links.
Or the other option is to cut and extend end links of sway bar by welding a tube (not much sterss there) ....
here are some pics:
Cheers!
The front has a firm feel to it when hutting speed bump, the rear floats and soaks the bump like there was none...
I am waiting for Skunk2 sleeves to retrofit rear struts with different coils...
Also, To get full benefit out of current sway bar se-ut I need to eliminate that ugly long bolt with guzzilion spacers because it has to much leverage and rotates LCA when sway bar is acitve!
P.S
I've decided to cut ends of sway bar and weld tubes to extand ends about 2 inches.
I have some DOM tubing (from my old jeep steereing set-up) I can use for this lil project!
