HELP! Coilover(spring rate) help!
So, I'm getting a set of Koni coilovers made with custom spring rates through a friend who is sponsored by them. I was wondering what rates I should use in the rear? I was going to treat the front as a normal Civic. Any suggestions are appreciated.
Guys who set up their EF hatches and CRX's for autocross purposes typically go with about 380-450 in the front and 420-500 or more for the rear. I think 380f/350r would be a really nice setup for the street. Personally, I would go higher in the rear to help with corner entry. An anti-sway bar helps with that also.
450/550 is borderline. Koni's aren't supposed to be used with anything higher than 500.
Why do you mention welding with regards to anti-sway bars? I thought they just bolt right up as long as you get different lca's.
My car handles amazingly well, but if someone not familiar with it were to try spirited driving they'd loop the car way too easily. Tha ass end is very wag-happy with those rates. It's amazing for auto-x, it's borderline unsafe for the street IMO. I know better than to push it on the streets though...
Not only the snap oversteer issue would be a problem, but the ride "quality" would be harsh.
I'd stick with rates lower, and more front-baised for a daily driven street car. 380/350 sounds better IMO. If you are not happy with the back end rotation you can always disconnect the front sway bar and add a large rear swaybar - this way the car still rides well, but can achieve lift off throttle oversteer if desired.
If I was secure in not losing mmy parking spot I might take you down the street in my 450f/550R rates hatch to show you exactly what I mean about the harshness of the ride, especially on ATL streets. On second thought that might not be a good idea anyways since the streets there are already very treacherous for lowered cars with 4-1 headers on them.
That means we need to get together other than the V!
