Brake caliper clearances
hey guys i have a 90 honda civic 4wd and i want to swap the calipers from a hatchback or crx to my wagon. the reason im doin this is because the 4wd wagon caliper is bigger and the like the SI hatch is flatter. so it touch my hub rims (they are 17") do you think it will work
Yea it would work but your downgrading. The 4wd models have the same front caliper as the Ex and Si.
Wrong offset... Your the only person who had clearance problems with a 17 inch rim. Those rims are not for your car Astuto. Trust me dont downgrade your calipers.
The offsets I had were fine. I had no issues with rubbing of the outer part of the caliper, no rubbing on suspension components, only the hub rubbing the bottom part of the caliper.
Of course this was only remedied by purchasing new wheels 8)
