2WD DD/MPG/WhateverHappens build
Figured I should start posting on this fella.
Scooped the gray 2WD from Nick (503Wagon) earlier this month when we were in Portland for the wifes reunion.
When I scooped her and got her to the in-laws house
The beginning of a VERY long, solo, sick, quiet ride. I believe this was Washington just near snoqualmie pass.
Scooped a door off of turbo-teg in Cle Elum
One of the MANY "every 100 mile" oil checks in Montana.
Made it to a rest-area just before Billings Montana and turned the back into a snooze-spot. I almost fit perfectly, almost.
Home and next to the RT that may run someday.
Got her home and immediately swapped a set of polished SI wheels on.
I also have steam cleaned all of the seats and will post updates on that. That horrible stain in the back seat is almost nonexistent now, and everything is cleaning up nicely.
Plans are to lower it, drive it a lot and try and get 40mpg until it sells for what I want out of it. Eventually I will put the new door on and paint it gray again for it to clean up.
