5 lug question
Would it be possible/safe to modify the hub to be 5 lug instead of 4 ? What I mean is cut the part off the hub the actually holds the lugs and get a new piece welded on that has the 5 bolt lugs ? If that's not clear I can try n re word it. I just want 5 lug on my rt with rear disk to match my type r front.
Here's another similar thread on it https://www.civicwagon.com/showthread.php?15631-RT-ITR-5-Lug-Conversion
This may have been said elsewhere and I'm just shooting from the hip, but if I were to attempt this in a similar fashion as to what you're saying. I would not chance cutting any hub parts. I'd press out the studs, fill weld the holes and have new holes drilled at a machine shop in the right pattern that you're looking for.
If you're trusting yourself for the work you might want to get as cheap as possible of a lug conversion spacer from ebay if they make one in this arrangement. I don't know if they do, so search around. But that could be used as a guide for the new bolt pattern.
But yeah I would not want to try to cut the face off one hub and try to weld it on to another and hope for it to be perfectly true and warp free. Seems like that would be a fine spot for something to fly apart at speed unless it was done professionally, and if it was done professionally it's a lot cheaper to just fill weld the old holes and redrill.
That said if I'm able to figure out a jig for it. I'll gladly zip these things out, wouldn't be too terribly difficult to do once jigged.
i am asking specifically for the rt
