Help! Brake vibrations.
Well I've been having brake vibrations between 90km - 65kmh. Anything over/under that it's buttery.
Last week i put brand new rotors on, and the vibration remained.
Yesterday I took an old set of rotors to get machined, and took off the brand new ones i put on.
This is what the front left brand new rotor looks like after 2 weeks.
if you look, there is a strange ring of what looks like a grab/release/grab/release. zoom in on the pic, the left of the pic really shows it off.
When I put the new machined rotors on, it was great and smooth for the 1st 100km-0 brake for bedding in the pads, after that it starts feeling like poo again.
What's going on here?
I'm going to pull my hair out.
Are you bedding in the rotors and pads each time?
http://stoptech.com/technical-support/technical-white-papers/bed-in-theory-definitions-and-procedures
Is that happening on both sides? Or is that just the front left causing the problem?
If you look at the pad is the wear on it even or is it wearing on one side faster than the other?
Any wheel bearing play? Just thinking if that were to get wiggly and cause things to start binding up in a funky fashion. I'm just guessing at this point though.
Also, check your pad for anything that looks out of place and your hub for movement.
Not in any order!!
The Check List!!
I did the rack-end bushing as well, need to adjust the pinion gear too.
I can't say exactly what did it but I have managed to get the vibration to a minimum. To the point where I don't AVOID using the brakes anymore.
- swapped that rotor out of course
- took the pads out, sanded them down on a sheet of 150grit, sprayed with brake clean
- greased the slide pins heavily.
- pushed the caliper piston all the way in as to maybe loosen it a bit if it was sticking.
- adjusted the pinion gear on the rack
- got an alignment.
i wish i could say which of the above did the most to help, but i don't know. it's not 100% perfect, but it's pretty good.
I went for an aggressive mountain blast and by the time i was done the problem is back. The new rotor is starting to look very much like the one i pictured in the first post. Something is F*CKED!
the replacement rotor doing it's thing again, a bit hard to see because of shadows and it's still on the car, but you get the idea.
Looks like uneven pad transfer.
Overheating the brakes can cause this.
A stuck/sticky caliper will cause overheating.
I'd suggest trying a new caliper.
I ran another test today out of boredom/curiosity.
I had a set of OEM replacement pads, at about 99%. scuffed them up and put them on. They barely fit with the full thickness rotor and thick pad.
So i take it out for a spin, driving along fine, hit the brakes, everything seems fine, actually firmer than before. So i'm thinking it's fixed.
Make it about .5kms before i start smelling burned brakes...
stinking real bad.
I turn around, hit the brakes a few more times thinking it will vibrate like crazy. It never did. But mad stink.
Pull it into the garage after not even applying brakes for at least 2kms, and it's raining. Couldn't even grab a spoke of the rim, so hot.
So it would appear that the caliper definitely stuck and the brakes were dragging even without applying them. The rotor was a nice blue color, but no spottiness.
I let everything cool off, put my 45% axxis pads back on, took it for a spin, vibrations back and the spots on the rotor come back.
Caliper replacement tomorrow.
Thanks everyone, i will let you know how it goes.
