CEL question, need ideas
91 RT wagon
Problem: When I first cold start the car and switch the headlights on the CEL comes on for about 2 seconds and goes off. Engine bogs a bit more than normal for a sec then it's fine. If I turn the car off then back on and turn headlights on no CEL....also if I turn the headlights on then start car no CEL.
Recently installed: New Igniter and 5000K HID bulbs
I installed the 5000K bulbs a week before the igniter and this problem did not occur, also I had 8000K bulbs in before and everything was fine. This problem became apparent the day after I installed the igniter. To me it seems like maybe there's a draw on the alternator maybe an excessive voltage spike right as the headlight switch is engaged.
Does anyone have any ideas?
http://honda-tech.com/honda-crx-ef-civic-1988-1991-3/how-pull-clear-cel-codes-your-obd0-ecu-3097979/
This morning I was sitting in the car without it on and the dash lights started flickering on and off like crazy! If I start the car it stops but I had to unhook the battery for it to stop
And yes I know where and how to check for codes and there are none.
