89' RT 4WD "Rozi" build in Hungary
Hi everyone!
So folks, i guess it's the time when I make a thread of my wagon build.
I decided, i make it today. Yesterday i got some photos from the body workshop. The work is passes well, and the car is almost finished. I'm very glad but I know, it will be a lot of work yet. Please let me share these pictures for you. I hope you'll enjoy.
I think they used Klokkerholm's items IN:2909591 for the left, and IN:2909592 for the right side.
As I promised, there are some photos from the body repairs.
The corrosion protection is ready, I think only the painting and the assembly is back, maybe a few days and it's done.
your health
closer photos soon
OK, hatch patch panels. Thank you for the information! :encouragement:
It's fit exactly or need to cut? He told, it's need to cut one site. And if you look at the photos thoroughly you can see the cutted area.
As you see it's all over genuine, because the MOT has yet to.
But after
at first:
new alloy wheels and tires
a bit lower body
new customised exhaust system
front and rear bumper lips (maybe painted bumpers)
wind fairing
darker, foiled windscreens
I see you don't have te small triangle side mouldings on yet, are you missing those or just didnst place them yet?
If missing, shoot me a PM, I might be able to help you out
Hi, i don't know, maybe this silencer it's an aftermarket bosal item. I also couldn't find anywhere.
It's very interesting, the bosal catalog brings two catalog numbers:
163-381 for the D16A6 engine,
http://www.catalogue.bosal.com/pages/exh_system_list.php?query_nr=2&make=HONDA&model=Civic+Shuttle
and 163-461 for the D16Z2 and D16A6 engines.
http://www.catalogue.bosal.com/pages/exh_system_list.php?query_nr=10&bosalnr=163461
The car at this time on the MOT test, if everything ok tomorrow she gets a new number plates. I'm looking forward to drive it.
But unfortunately I have a bad news. It looks I need to replace the cylinder head gasket, because there is a little problem with a cooling temperature. It's jump up and down when the car stops after the road (while the engine is working). The thermostat, the radiator and his cap are new. So, I don't know what is this, but I guess this is a beginning of a cylinder head problem.
Thats all, the car is 25 years old and this gasket as I know was made of klingerit and maybe it's too old. It's time to replaced. I know what will be my next month's activity.
Remove the radiator cap and check the coolant level. Look in the radiator, not the plastic overflow bottle.
I refilled up the whole system when I replaced the thermostat, there is about 4,5 L coolant inside. So the levels are ok and the bleeding process also. Unfortunately here will be another problem.
Thanks! I have the side mouldings just I don't have any time yet to put on the car.
