stock struts? 1988 RT4WD
I am having a hard time finding some stock struts for a 1988 wagon RT4WD model. I have the rear taken apart now and it seems like a great time to stick some replacements in. The issue is I cannot find any place that sells them.
I am looking for a stock, unscrew/bolt mine, compress the spring, put in new item, reinstall and have the same height part. I do not want to lower it or cause any loss of towing/weight capacity.
Does anyone have any part numbers or suggestions?
Amazon has these in stock: http://www.amazon.com/KYB-341136-Excel-G-Replacement-Shock/dp/B000C3ZCPI/ref=au_pf_ss_4?ie=UTF8&Make=Honda|59&Model=Civic|752&Year=1988|1988&carId=001&n=15684181&s=automotive
Good luck!
Struts
https://www.tirerack.com/suspension/suspension.jsp?make=Bilstein&model=Heavy+Duty+%28B6%29+Shock&autoMake=Honda&autoModel=Civic+Hatchback&autoYear=1990&autoModClar=
Springs
http://smile.amazon.com/gp/product/B00C7LMKGC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I've not done the front yet, but here's it all sorted out in the rear. Just to see you're not losing any ride height. I actually gained about a quarter inch.
I'm really pleased with it so far. Yeah it's not the same spring/strut setup in the rear but these springs are meant to haul a heavier car, so they're suited to the task. They are well beefier than the stock ones that I took out.
Greentea: I was not trying to put that much into shocks at the moment.
I did find Monroe 71232 that seems to be saying they are a direct stock fit for the RT4WD wagon.
Glad there is something still out there that doesn't cost an arm and a leg for those just looking to repair.
