PS rack removal on RT4wd
Hey all. Ive been doing searches but cannot find any info on removing the PS rack in my RT4wd. Im wondering if there is enough clearance to remove it through the wheel well without disconnecting the rear driveshaft or if i will need to disconnect it. Im also wondering what the best replacement replacement rack would be
Thanks
Thanks
take your outer tie rods off(you might can leave them on but i doubt it.)
IMPORTANT: TURN YOUR STEERING WHEEL ALL THE WAY LEFT
this pulls the left tie rod in close enough to clear the supports
Decouple from your steering column.
pull the shield off the driver side. 2 14 mm bolts on the rack and 2 more on the bracket.
you may have to unbolt the sway bar to move it out of the way.
pulling down on the rack while pushing it towards the pass side should let the tie rod just barely clear then head the other direction.
You're on your own on hoses though, i clipped all of those because i swapped to a manual rack/subframe with quaife internals
Thanks for the replies, this is the least agro and most helpful forum ive ever used
It'd probably make things easier, but I was able to R&R my rack without doing so. I did loosen up the sway bar though.
This is very true. But when you're on your back in a driveway instead of under a nice lift, and when your wiring harness starts cracking/breaking as you look at it, you try to talk yourself out of removing anything you don't really have to.
