My 88 wagon
I just bought an 88 wagon (dpfi automatic). Car only has two dents or rust in it that I can find so far. It was only running on three cyclinders when I got it home. Did some routin maintanence on it and found one of the spark pins inside of the dizzy broke off. Replaced the dizzy, rotor button, wires, plugs, and valve cover gasket and it runs prefect. Now all i need is a passenger side axle, passenger side lower control, and a passenger side radius arm and it will road ready. Radius arm is broke and the pervious ower continued to drive it till it destroyed and the bushing and screwed up the control arm itself. have big plans for it obd0 to obd1 swap, automatic to manual swap, poorman type r, ys1 cable, wheels and suspension. Then autocross it. Its a true diamond in the rough.
That is a rusted out front crossmember.
Did if get into the rails or anything else?
good to have another GA member.
my rig is an 88 as well.
Tried to get a close up of the three yellows.
