1993 Nissan Axxess
It's not a Honda but I couldn't pass up the deal. The wagon has 178,000 kms or 110,000 miles on it. Fully loaded with a moon roof. Unfortunately it's an automatic. I wasn't lucky enough to find the five speed AWD Axxess. This was the first year it has been winter driven...and now the bad it has a blown transmission. I am planning on replacing it with a JDM tranny with low kms. That said I only paid $300.00 for it. Here are the engine specs...I will post some pictures when I get it home this weekend.
Specifications
Bore × Stroke: 89.0 × 96.0 mm
Max power: 140 hp (105 kW) @ 5600 rpm
Max torque: 152 ft·lbf (206 Nm) @ 4400 rpm
Valve Configuration: SOHC, 12 valves
Compression ratio: 8.6:1 (9.1:1 for early 1989 240SX
Specifications
http://www.canadatrader.com/result/deta ... no=1&srt=4
http://ottawa.craigslist.ca/car/528227137.html
Cheers
