89 RT4WD Wagon - Upper Ball Joints
My mechanic told me I need a new upper ball joint on the passenger side. However, he says that in the 88 and 89 year wagons, that the upper ball joints cannot be removed and replaced separately, that they are part of the upper control arm assembly. He says that in 90 this changed, and the upper ball joints could be removed/replaced independently. I called a local Honda dealer and the parts guy says the mechanic is wrong, and that the UBJ is available separately. There is a big difference in the price, $8 for a separate BJ, versus $130 for the upper control arm with a BJ. I don't want to get into an argument with the mechanic since he usually seems to know what he's doing. Does anybody know the straight scoop on this?
Wow, $8 for a BJ. :twisted:
I found my shop manual (89) and if I understand it correctly, it says you can change the ball joint in an 89 control arm, but you need a special Honda tool to remove it. Maybe that's why people say you can't replace the BJs in the 88-89s, cause they don't have the special tool? Anyway, I'll look around for a 90-91.
some of them are pressed in, and then welded from the factory..thats the point of this thread.
