Brake Bleeding Woes After MC/Caliper upgrade
I recently upgraded to Legend/Prelude/ITR front calipers, 15/16" Prelude MC, front and rear SS lines and AEM pads w/ '91 EX rotors on my '89 DX wagon. I bench bled the MC twice because I wasn't sure I did a good job the first time around (I was right, lots of bubbles left inside). I also replaced the wheel cylinders outback. At first when I started to bleed the system I was getting no pedal and uneven pressure at all of the bleeders. A few more laps in the correct sequence and I have SOME pedal and I'm getting fresh clean air-less Motul fluid out of the RR and LF with healthy pressure at the bleeders. However, the LR and RF are barely spitting out any fluid and more importantly the pedal does not sink completely when the bleeders at these corners are cracked. Does anyone know if those 2 corners share a line that may be obstructed? It would have to be uncommon to the other 2 which is what throws me off. I think his set up has the potential to put some teeth marks in my steering wheel but certainly not with air/crap in the lines. If anyone can shed some light on my situation It would be greatly appreciated.
