center console manual/auto
Does anyone know if the auto center console (around the shifter and ebrake) is the same as the manual? I have the auto console and I converted to manual, so wondering if i need a new console or if I can just buy the boot and use the auto?
And does anyone know what make/model or if its just ESDM that the console below the radio that has the ash tray and cigarette lighter is?
thanks again
The center screw holes and the rear tabs line up however you'll notice its a bit shorter. Not shown but the manual console is notched up front to clear the shift cable.
Hope this helps!
Let me know if you need additional pictures. I can take some tonight.
THe 2WD Manual use the same transmission as the Sedans and CRXs/Hatches, they are shift linkage types.
So, there is a difference between the 2WD manual console and the RT4WD manual console.
Yes there is a difference between the linkage and cable trans.
Just wanted to post the pic to show visual comparison.
Thanks!
