new wheel studs needed?
Hi folks,
I just bought a new set of wheel which is Rota Dr-21. I think I need a new set of wheel studs and open end lug nuts to make it work. Is there any specific size of studs and lug nuts I need to get? Thanks
The studs should be 12 X 1.5 and you can look on the internet they have long shank import lug nut for like a mag wheel you can get a set around $30-$60 for good ones or get a set of extended lugs and nuts. Check out these sometimes these maybe more depending on if you want IDRA ones or just for looks. Hope this helps.
http://www.importdpsonline.com/skunk2/s ... 50699.aspx
maybe not as long as mine but if your only holding on by a thread or 2 that cant be a good thing.... a smaller end isn't the answer if you ask me
Googling that I found someone who posted this: 'For UNS/ISO Threads less than 1" in diameter, and where the nut is of the same material, and equal or greater strength compared to the stud, 1/2 the stud diameter in thread engagement length will result in thread failure at the same time as tensile failure of the stud.'
So, if you get 4 turns you might be fine. But this doesn't take into account any movement or directional forces on the nuts, etc. But make 100% sure your wheels are torqued to spec.
HTH
