oem rear lower control arm with st swaybar?
well i installed my rear swaybar with those hokey brackets that attach to the shocks. since the oem control arms i got were still drying. and after looking at how the swaybar installs and how it should install, I'm wondering if i can flip flop the oem control arms? right on the left and vice versa. so the swaybar mount faces back vs the front. this is the only way to mount the st swaybar on a rt cause of the rear diff mount.
here is how it is now (the bushing should be on the other side facing the front and the bracket on the shock should also be in the front)
pic of the RIGHT side control arm (need that swaybar nub facing back instead of the front) and yeah i see that the bushing is popping out
and a huge shout out to deesracer for pressing my bushings out. And cleaning all the gunk off them too!
st's instructions showing the proper way to mount on a crx with the heim joint in front of the shock as well as the bushing in the front of the bracket
any insight will be greatly appreciated.
here are the pics you sent me
and here is a pic of what mine looks like now. i may try and mount the heim joint to the other side of the sway bar to the control arm spot on the back side and use a washer to make it flat
