lowering my wagon, GC sleeve hight estimations?
Lowering my wagon this weekend and I calculated I have about 5 inches to lower till my mud flaps scrape and about 3 to tuck my wheels so the sweet spot is 4 inches or so. Now, I am going to be swapping out the rear struts for regular EF struts which will make it sit lower, and I'm using ground control sleeves and I'm trying to decide whether I should just run the springs and leave the adjusters off (gives another half inch of drop) or if I should keep em on and run em all the way down?
guess I wasnt clear. I'm trying to get tucking and I was wondering if it would be necessary to remove adjusters to get it low enough
do you have a pic of how it sits with those settings?
hahaha, jk. Where you getting the bag setup from? or are you custom making it?
the GC's won't be compressed off with the car jacked up
edit: found how to decode the part numbers and figure out the spring rates. didnt think to go about figuring it out that way. slammage comes tomorrow 8)
