Brakes dont work after replacing the lines
I replaced the front left and right brake lines on my rt and now my brakes sink all the way to the floor, ive replaced the master cylinder before and i dont think thats the problem, but im not sure.
my car hasnt ran for 4 months and i did the brakes right before i finished my swap.
im running the fake ITR front brakes , the rotors are new the pads are new and i took the car to the shop and they tried to feed me a line talking about the rear brakes need to be worked on before my front brakes will work and i KNOW THATS BULLSHIT!
becasue my rear brakes aint never worked!
long story short, what could cause my pedal to sink , the brakes worked well enough before i got new pads/rotors/lines the mechanics trying to tell me i need a bigger MC or booster to compensate and that would make sense to me if the brake setup didnt ever work before...
man i put the dual piston acura calipers on mine and didnt change a thing and i stop fine ....
ive been told i need all kinds of stuff but it aint broke so i dont fix it ..
bleeding the lines?
check if rears lines are leaking?
Honda did this incase one of the lines started to leak, it would leave you with some braking power instead of no braking at all.
we adjusted the rear brakes and rebled the system and only a few bubbles came out and still no better response, theres a whining noise from the master cylinder and we decided the only thing it could be would be the secondary piston in the master cylinder isnt engauging enough causing a lack in pedal response, because the system still holds pressure without the car on, still very confused to as why the pedal is spongy when the cars on if theres no air int he lines.
Yeah it's always better to have a friend.... to hold you beer. LOL
Anyways yes re-bleed the brakes sound like it maybe air in the system for one. But I alway tell my customers if you can PLEASE GO WITH NEW NOT REMAN. In the passed I have had several issues with reman. BRAKE!!! it's you life we are talking about. Don't go cheap you and you family and possibly other people around you. It does make a difference
Took it back to the shop and no luck the mc increased the ability to grab the rotor but it still doesn't compare to the way the brakes felt before I used to be able to lock them up now when I slam on my brakes they barely slow the car but it's better than before im losing my patience lol
The brakes are 93 ls rotor
Milled bracket 94 vigor (same as accord )calipers
Integra type r pads
Same setup found in quick links
The setup worked before they used to stop on a dime!
from my experience-the brake booster.
good luck
