cambering wheels
hey guys theres probably already a thread on this but i was wondering what you guys did for your wheels as far a cambering my tires are wearing really bad on the insides and i cant find a camber kit anywhere help thanks
http://cgi.ebay.com/ebaymotors/RHINO-CA ... enameZWDVW
Along with this:
http://cgi.ebay.com/ebaymotors/88-89-90 ... enameZWDVW
Take it to get it aligned and whoever does it will fix the negative camber.
Note:
I don't know about that rear camber kit, it was just used as a reference. I have the rhino front and it works pretty good. I've had it for a while and everything is ok with it.
http://cgi.ebay.com/ebaymotors/88-91-89 ... enameZWDVW
Yes, Civic/CRX is the same as wagon as long as you stay year specific. (88-91)
I used ingalls camber kit in the front (adjustable upper ball joints) and I used nothing in the rear. The rear is not the driving wheels if they are being worn down fast then you have more then just a camber issue. I'd look into worn bushings in the rear causing toe.
