ef shuttle tie rod end ball joint and front hub replacement
I'm asking this for my mate's shuttle (2wd sohc d-series). seems his shuttle's tie rod end ball joint needs a replacement and hard to find here in nz.
just wanna ask u guys if ef (hatch or sedan), eg (hatch or sedan) ek (hatch or sedan) 's tie rod end ball joint can fit to our ef shuttles?
I've been searching but couldn't find anything. (sorry if this been discussed before).
and also..
front hub is fcked and seems it need a new hub where to put the bearing in. just wanna ask if can we use an eg, ef (hatch or sedan) or ek's hub?
thanks in advance
and also..
thanks in advance
thanks heap!!
what about eg or ek?
Honda stocks them, pretty cheap too. Make sure to get a wheel alignment after changing it
thanks andrew. i was gonna pm you bout this. haha.
