88 Honda Civic ShagoWagon
I'm new to the wagon thing, but here is my build thread! I recently picked up a 88 2wd for 800. When I got it, there was oil dripping on the ground, AC was gone, front end damage, interior was dirty and smelly, missing some small things here and there. rust on the rear, the whole rear was repainted. unfortunately I had not taken any before pictures. However, here is what I have done so far.
Timing belt
Water pump
Timing belt tensioner
Alternator belt
Crank seal
Cam seal
Oil pan gasket
Valve cover gasket
Rocket arm O-rings
Distributor O-ring
Removed all that black crap off the valve cover
removed and cleaned the whole interior and carpet.
Put fabric on the headliner
Got a clock!
A couple small interior plastic pieces.
Here are some pictures!!
Thanks for looking! more to come!
Timing belt
Water pump
Alternator belt
Crank seal
Cam seal
Oil pan gasket
Valve cover gasket
Rocket arm O-rings
Distributor O-ring
Got a clock!
I remember seeing this on Craigs list also.
You do all the work yourself?
Are you planning on paint or many other mods or add ons?
The hood is open, I feel stupid. And below, in those boxes are brand new parts I need to install. Headlights, brand new. rear toe arms, the factory adjustment doesn't have enough adjustment for me. and the rock auto box is a bunch of stuff not for my car.
